fbethe PowerBook de Faïence
Inscrit le: 14 Nov 2003 Messages: 92 Localisation: Paris 5
Posté le: Lun 10 Jan 2005 à 22:28 Sujet du message: Mardi 11 janvier nouveaux powerbook... |
Je lis un peu partout depuis quelques heures qu'Apple va annoncer demain la sortie de nouveaux powerbook... du G4 un peu plus rapide...
"At the high-end, the new PowerBooks will top out at 1.67GHz, sources say. Other chances will be similarly minor: the 80GB/4200RPM hard drive found on the current high-end 15-inch and 17-inch models will be replaced with 100GB hard drive spinning at 5400-rpm. The video card at the high-end will remain ATI's Radeon 9700, but it will be given a boost from 64MB of memory to 128MB. The PowerBook SuperDrive will also gain official support for DVD+R media, along with the DVD-R discs that have always worked.
At the low-end, the 12-inch PowerBook will be upgraded to 1.5GHz. Hard drive size will remain at 60GB, but the drive will be upgraded from a 4200-rpm model to 5400-rpm drive, marginally improving performance. Other specifications will remain unchanged from the current 12-inch PowerBook.
All PowerBooks will also be upgraded to the new Bluetooth 2.0 specification with Enhanced Data Rate, introduced in November. Bluetooth 2.0 is about three-times faster than Bluetooth 1.1, consumes less power, and is backwards compatible with Bluetooth 1.1 devices."
 _________________ --------------------------------------
www.chantairelle.com
Au coeur de Paris, la Haute-Loire a du goût
Restaurant et Boutique Gourmande
Turi PowerBook de Saphir
Posté le: Lun 10 Jan 2005 à 22:56 Sujet du message: |
Encore des rumeurs ?
Le mieux est d'attendre demain vers 18h pour savoir enfin si mise à jour de powerbook y aura ou si mise à jour de powerbook y aura pas... _________________ PowerBook 15" 1,67 GHz, DD 100 Go, ATI 128, SuperDrive
PowerBook 12" 1.5 GHz, DD de 100 Go, Combo |
Posté le: Lun 10 Jan 2005 à 23:10 Sujet du message: |
Je confirme ce que dit Turi, encore des rumeurs.
On est à moins de 24h des annonces, il suffit d'attendre.
Je verrouille ce post pour continuer dans le sujet déjà longuement abordé sur les nouveaux PowerBook (rumeurs)... _________________ Ludovic
Posté le: Mar 11 Jan 2005 à 14:17 Sujet du message: |
au passage, il existe déjà un sujet qui traite TRÈS largement la question des machines à venir... et ce n'est pas le seul.
merci de faire une petite recherche à l'avenir.
je re-ferme le sujet  _________________ Vincent
